Joel Talka
Almost there with the motor install, the plumbing took more than I expected..just finding stuff out there. I have two more questions for you all and certainly appreciate your input.
1 - Front end height adjustment - Should I be loosening the lower control arm bolts when I am trying to adjust front end height? I can turn the adjusting bolts to a certain point and then they become almost impossible to turn.
2 - Antifreeze - I'm running a Champion aluminum radiator and an aluminum heater core. What antifreeze should I use to protect the aluminum? Also, should I use distilled water? The last one I did about 10 years ago, Champion radiator too, I was told to use HOAT antifreeze which was orange as I recall....
I managed to get those "Z" bracket clips on, boy, what a PITA!
Thanks in advance!!
Joel
Thanks in advance!!
Joel
