Moparcoastie
Greetings everyone,
I fully expect to be told I'm crazy because all I can find online for sale are 7290 series U-Joints with inside C clips for my 67 Coronet R/T. However, I was just under the car two days ago and the U-Joints on the car have outside snap rings on both the transmission and differential yokes. Does anyone make 7290 series U-Joints with outside snap rings? Is it possible to have outside snap rings and inside C-clips? I looked inside the U-Joint to see if I could see a C-clip but did not. However, I could have missed them visually. There are definitely snap rings on the outside, though. The ones in the car checked out fine (no play) and are non-greaseable, but I'd like to locate a source to buy them in the future if needed.
Is it possible my completely stock and original driveline might have something other than a 7290 U-Joint? They ones on the car are definitely not the smaller 7260 version.
In case it helps, I have a 67 R/T with a 440, 727 TF, and an 8 3/4 rear with 742 case.
Thanks in advance for your help! You guys are always offer the best advice!
-Brian
-Brian
