ddpsnake
Moog t412 is the right socket to remove the upper ball joint on my 71 salty.Just need to know. Also the moog k772 is the right ball joint.Thanks again.
Thanks a bunch.Moog K772 is the upper ball joint, it fits 1965-1974 SATELLITE cars. Don I used it when I did my complete front end rebuild on my car last year
Great advice Kelly,wear did you get your alignment done.
sounds like a good idea I'm just about to replace inner and outer tie rod ends with sleevesyou can also use the bigger C body tie rod ends that are stronger then the B Body tie rod ends. C Body cars use the 11/16 shank tie rod ends and B Body cars use the 9/16 shank tie rod ends, they bolt right up with no modifications. I did this on my car. You will have to use a C Body tie rod adjusting sleeve. PM if you want more information about the C body tie rod swap, it is worth doing
Your car is salty ? I have never licked mine. Maybe mine is as well.Moog t412 is the right socket to remove the upper ball joint on my 71 salty.Just need to know. Also the moog k772 is the right ball joint.Thanks again.
done , thanks those aluminium sleeves are very cool
So are the UCA bushing the same from your car to my car? if so do you have the part numbers from rock auto.Thanksss.they are a great upgrade over the stock type sleeves and they are alot stronger to.
I'm getting new upper a arms from firm feel1965-1972 Satellite. you will need 2 sets
MOOG K7103 Offset Bushing
Front Upper; Optional; Eccentric Bushing; Provides Additional Positive(+) Camber Adjustment
