Valve cover selection for trick flow 270s with t&d rockers
TexasRoadRunner68
4:28 PM
Dallas,Texas
Anyone else running trick flows with t&d rockers? Preferably 1:6?
I’m in between the trick flow valve covers and refinishing some finned Mickey Thompson valve covers. I just want to make sure they are tall enough before dumping money into them.
The trick flows would need to be drilled for filler, breather, etc?
I can't speak for the rockers, but I had to do some grinding on the ends of m/ts to make the fit over the end pedestals of TF 240s.
The thick black felpro gaskets give you a boost in height as well.
Dan Medice makes nice valve cover spacers in various thicknesses.
I got some for my small block 340. I did have to put a little notch in either end so they would go on to the valve cover studs with the rockers bolted in position.
