Glenwood
- 2:09 PM
- Jun 19, 2015
- Kawartha Lakes, Ontario
I could use a bit of guidance regarding a set of 906 heads I'm working on...
I bought a set of 906’s sometime ago for my 413 build, because they supposedly had already been rebuilt and had about 10,000k on them before the owner had aluminum's installed.
I’ve torn them down to clean & inspect and I can see that they have hardened exhaust seats installed as well as bronze guides with some milling on the guide ‘bosses’ to accept double springs I guess. The intake valves had a good amount of carbon and oily soot like build up on them, which makes me leery of the guide clearances. They seem tight to me, but I don’t know how to check them properly. I also checked them for flatness and they are .002 or less, so I’m thinking they should be fine for the thin head gaskets I intend to use.
I gave them a good cleaning using a scotch-brite pad and reassembled. I did a leak test with varisol and all valves are seeping slowly. The exhaust valves were seeping noticeably first, but very little over a few hours. Overnight, the chambers are still half full with the intake runners having a little solvent leaked into them now. Do you guys think these need regrinding to seat properly or does this seem to be an acceptable rate? I’ve read that lapping is not recommended by engine builders.
