I can tell you that in a 66 Charger gauge cluster, the condenser is on the 12 V ( input ) side of the 5 volt mechanical voltage regulator. On your circuit board you will need to figure out which of the 3 terminals that actually is. You will need to follow the traces. The regulators 5 volt output feeds one side of the oil pressure, temp and fuel gauges.
