steve from staten island
- 4:48 AM
- Sep 24, 2012
- staten island,ny
I have a stock distributor with a Petronix replacing the points. I read were i should replace the voltage regulator with a solid state one. Is this true? Everything is new on this car, wiring alternator Voltage regulator, everything is tight and clean. When i start it especially after a day or two the amp meter is swinging back and forth from the middle to the full charge side. The interior lights flicker slightly. Then after a couple of minutes the gage settles down and all seems ok. The voltage regulator is a Chinese knock off I'm sure of that. Should i replace it. What are any thoughts and thank you for the help
