Can you add a tic-toc-tac to a car that didn't originally have one easily? Are the plugs there and possibly just not being used?? Or does it have to be wired from scratch?
yes you can add one...remove the delete plate and put it in there. youll need a hot wire ( key off )...and a wire to the (-) of the coil you can "tap" the dash lights to light it up....very easy! im not sure if the harness is universal for tac or tac-less cars or not...youll have to do some "investigating" with a test light
