WTB Wanted to Buy or trade 1970 Plymouth sport satellite in good condition
Acworld34
12:09 AM
Washington DC
I sold mine during covid and now regretting it. I picked up a 1971 Chevelle that is more a resto mod and has a 454 stroked out to 496 with a super T-10 fourspeed.
I would like to see if there is any interest in trades or selling a 1970 sport satellite outright and the price.
This is a picture of my car. It runs and drives and has a list of things done to it. Holley EFI sniper etc...etc...
1971 Chevelle Upgrades​
  • 496 Stroker Motor w/4 bolt main block, Balanced and blueprinted
  • Holley Sniper EFI
  • Griffin Thermal Aluminum radiator
  • Gas tank with in-tank fuel pump
  • MSD Street Fire HEI distributor
  • Flow master 50 series street mufflers Flow master 2.5'' exhaust
  • Borg Warner Super T-10 4 speed transmission -2:43 first gear
  • Transmission cross member powder coated
  • Hurst Super Street Shifter
  • Center force dual friction clutch and pressure plate, throw-out bearing
  • SFl-rated flywheel
  • Lakewood block plate and scatter shield
  • Starter/replaced
  • Optima battery
  • Auburn Gear Pro Series posi-differential with all new bearings and seals
  • 12 Bolt rear differential housing with new seals, bushings and powder coated Richmond 3:55 rear gears
  • UMI Performance rear upper control arms and boxed lower control arms with urethane bushings
  • All new suspension bushings (front and rear)
  • New front and rear heavy duty sway bars
  • New pitman arm, Tie rods, sleeves, center link
  • New Moog Front and rear coil springs
  • Rear Suspension airbag leveling
  • New Cardone Quick Ratio steering gear box
  • All new brakes, Backing plates, calipers Master cylinders, distribution block
  • New Body bushings (except 2 below the trunk
New Engine Bay wiring and relays
