what is the correct type of hose that was used as the water drain tubes for the six pack base on the a12?
I always thought they were 5/8 heater hose with put with a different part number because it’s shorter. I’ll say this, that’s what I’m using on my 70 AG carwhat is the correct type of hose that was used as the water drain tubes for the six pack base on the a12?
good, thats ok with me, I just figured it might be special .It was the same ribbed heater hose for the cooling system. No special stamping or numbers, just a piece of hose cut off the bulk roll.
That’s what I saw in yards in the day but thought I read too. Thanks R413It was the same ribbed heater hose for the cooling system. No special stamping or numbers, just a piece of hose cut off the bulk roll.
NOPE!I believe that the later built 69 A12 cars had a molded 90deg hose on the rear drain to prevent water from being drained on to the starter relay. I don't have a pic at this time but I will search for one to post.
NOPE!
