water temp guage sender location on 440
gto64gto
6:01 PM
Tabor City, N C
I have a 440 in my Satellite. I bought a set of mechinal Auto Meter gauges. Does anyone know of a easy location to install the water temp bung on a 440? Thanks so much.
i always try to get mine into the water pump housing.factory location is a bit small,but you can run an adaptor to make it bigger if looks dont matter a ton.i put my current one into the spot where the heater hoses go(not running any on my hotrod)some of the water pump housings have three holes where the heater hoses hook up,if yours does use the extra hole.
there should be a plug on the water pump housing close to the dizzy. :blob1:
remove the plug and SCHTIK IT INNDERE
