What cam for a 440 six Pack
Loubo40
10:27 PM
Long Island
I have a 67 440 in my Coronet. it now has a six pack which works pretty well.
the motor is stock otherwise and i would like to keep it that way.
it has an overdrive 4 speed and 4.10 gears.
what cam may work well to add mid to top end power without adding headers and such.
this would be a weekend driver.
I'd say something in the 270 deg duration; 112 LSA and about .460" lift. Putting a high overlap cam that has an ideal RPM range from 2500-6500 with stock manifolds is pointless IMO. Especially with an OD tranny.
Summit sells a house brand cam that is similar to the original split profile "Road Runner" grind but bigger. 224/234 @ .050, .466/.488. SUM-K6401, but it is only available as a single bolt. I was going to put one in my 6 pack with overdrive Tremec and 3.54 rear but I went with aluminum heads and headers. Just a suggestion...
