What is the driveshaft degree on a 73 dodge charger
Street fighter
8:57 AM
Vicksburg,Miss.
I have a 73 dodge charger I need to know what is the correct degree of the driveshaft using a angle degree tool need to know if the driveshaft angle is correct, have a small vibration in the car at high speed, have balanced all tires all new parts on the front end.
I don't know the answer for your model/year but the FSM will have it
If you have not altered the stance or changed anything concerning the rear end, the pinion angle is probably fine. Maybe just need a U joint or check for a bent drive shaft.
