What is the height of the baffle inside a 426 Max Wedge Valve Cover?
MadMax3426
8:15 PM
AZ
Does anyone know the measured height of the oil baffle inside a 426 Max Wedge valve cover?
From the lower lip of the valve cover to the measured height of the baffle.
Because of the adjustable rocker arms that were used Chrysler moved the baffle plate higher into the valve cover and this is the measurement that I need to know.
The regular big block valve cover with not work as the rockers hit the baffle.
Well it looks as if I've stumped the masses with this one question.
So I guess this answer may go by the wayside.
Having pulled the valve covers off of my 63 Savoy 426-2 TMP HC engine a while back only to discover that someone had previously removed the oil baffles and then found the same on my 64 Belvedere 426 VMP HC engine as well.
Thanks for looking.
