Secret Chimp
I can't figure out what brackets I need to get my kickdown and throttle cable hooked up correctly. There's info out there for new Edelbrock carbs, but not old stuff like what I'm using.
I'm moving from a stock cast iron 2 barrel intake to a non-RPM Performer manifold and a Carter AVS off of a New Yorker. I presumably don't need to change anything on the carb itself since the linkages are already for a Chrysler, but what do I do about the throttle cable and kickdown linkage brackets? What do I need to get?
I don't want to drop $80-$120 on a kickdown cable kit if I can just get an aftermarket bracket and keep my original rod kickdown setup. Unfortunately I don't have the means to just make something out of plate.
