What wires to use with headers?
Mopar Man USA
1:59 AM
McKinney TX
What are my options for spark plug wires on my 360 with headers? Straight boots are fine except for the driver's side rear two. Those must use 90 degree boots for those two, to clear the header tube passing over head. I'm having the headers installed this week. Also, I'm converting over to an HEI aftermarket distributor and coil for Chryslers that I picked up on Ebay, so the wires have to have HEI ends for the cap and coil.
Regular wires are fine. You just have to sort out which cylinders get which type of boot. For my BB in the 69 RR with 2" headers I came up with brackets and custom wire routing. Even using the heat insulation sock in a couple of locations.
