Good evening, I have a 1969 Coronet that came with an 8 1/4inch rear end. Originally it had the 318 engine, I will be replacing with a 440ci probably in the neighborhood of 500hp / 727 trans. I’m assuming I will probably be needing a little bit heavier of a rear end. I’m not planning on doing any drag racing, etc. and will basically be running a little over stock size 15 inch tires. (No slicks). My question is would an 8 3/4inch rear end be enough or would y’all recommend something bigger? And a good source for the rear end.
