Barsby340
Hello, I am just wrapping up asseembling my new motor and I was hoping for some insight into which spark plugs to run. The engine is a 505 approx 10.6:1comp with trick flow heads. The cam is a Hyd roller with 600 lift and 243/251 dur at 50. Im also using a Sniper xflow system with the sniper ignition and distributor. Im mostly looking for others are running as a baseline. I can adjust the temp range from there once I get it running. Any input would be greatly appreciated
