no rusty i dont....just got breathers on both valves?i did some goggling on the pcv valve and doDo you have a PCV valve on it? If so make sure it's working.
Connect it to the BIG vacuum port either in the base plate of the carburetor or the big one on the intake manifold and plug the PCV valve into the valve cover. I bet that will solve your problem.
oh okey but do i do it on both sides or just one?thanks man
Just one. Leave the breather in the other side.
