Anyone here running one of there Spacers ? And are they worth the money ? Thought I'd ask before spending $144.00
Sounds Good Gentlemen ! Ill give it a Shot !!
I also have tried the $20.00 spacers and noticed the deference as soon as i hit the accelerator so spending almost $150.00 is a big jump...But well worth it if it Does the Job !!
Like I reported above....I went from 11.045 to 10.989 WITH NO OTHER CHANGES from run to run.
That, if you can't do the math (lol), is .056 seconds which is more than 1/2 10th.
I am a believer.
When I called Wilson in preparation to buy the spacer (from Summit) they recommended the 2" over their 1" for my 4150 carb setup.
Mike the HVH super sucker worked for me made my car faster.
I just removed my 2 inch open spacer and picked up 4 10ths, from 12.96 to 12.51 no other changes. I put the spacer on back when I had the Purple shaft 296 557, It picked up 3 10ths then. But now I'm running way less duration with a comp cams custom solid roller, for better streetability.
