Wilwood Hydraulic Clutch Master Cylinder Stroke
Charlie Brown
2:59 PM
Vars, Ontario, Canada
I'm installing the above that has a .75 inch bore and a 1.4 inch stroke. What is the minimum amount of stroke of this cylinder in order to disengage the clutch? Would 1 inch be sufficient or do I need to use the complete 1.4 inch stroke of the cylinder. I'm using an internal hydraulic release bearing. Thanks, Charlie.
I went by this.
