Window Fuzzies 1964 Dodge 330
Strukkingfuggle
1:07 AM
Vancouver
What is the proper term for the horizontal sweeps/fuzzies for the window that attach to the door and inner trim? Mine are fried ... supplier Just Mopars?
Thanks!
J-M
How do you know what bead it is? Flat or Round ... what's the difference and where is it located?
actually I am not sure, but I remember asking Dante when I was buying it & I chose the part number that I posted above. Going from memory it was something like one accepts a chrome trim finish piece and the other doesn't. So the 330 would not have the chrome trim.
If I recall this one set does the inside and outside of both doors and quarter windows.
I'd call him to double check the difference between your two choices.
1) 970467 63-65 B BODY SEDAN $110.00
2) 970468 63-65 B BODY SEDAN W/ FLAT BEAD ON INSIDE $110.00.
Good luck.
My go-to source for these (which are known as "cat whiskers") is Restoration Specialties, see here.
I just ordered all my side window stuff (run channels, whiskers, etc) from Restoration Specialities. Talked to Dave and he seemed to know all the pieces I needed for my 65 Belvedere. He is shipping by mail too which helps on this side of the 49th. Just waiting for things to arrive.
http://www.restorationspecialties.com/index.html
Good to know ... looks like my window channels might last a while but the whiskers are shot ... I am looking at the installation sequence andit looks likw the whiskers are likely installed AFTER the channels. I think iy may be worth replacing those at the same time as I don't want to mess with the whiskers later. I might end wrecking them ...
