rustytoolss
I need to replace my window glass channel material. How do you replace the track material that goes in the front wing window track ? can it be done in the door...or do you have to remove the vent window ????
Thanks, that helps a lot.You have to pull the interior door pulls, cranks and door card anyhow to do the job. Just pull the entire glass assembly out and put it on the bench, it'll save you a LOT of grief. You need to adjust the lower stop down, so you can get the cat whiskers off. Can't pull the glass out of the door with them in place if the regulator track is attached to the lower edge of the glass.
Doin' glass...
Drivers side..
Broke my 7UP Pop Machine today....(Superbird Restoration)
Passenger side..
