Wire question
ram250098
8:38 PM
Cookstown Ontario
I have moved my battery to the trunk and have one wire left to hook up. The the dark blue wire with the fuseable link from the starter relay that goes into the fuse block and comes out red under the dash, from the My Mopar wiring diagram I am not sure what it feeds. I just really need to know if this can be hooked up to the battery Positive or should it be switched.
AL
I looked it up in my schematic book...The blue from the fusible link, throught the bulkhead, turning to red is the ammeter input feed. This wire should remain battery positive.
Great thanks very much, my car had a non Mopar relay so I needed to be sure. I can hook that wire straight to the battery then?
Thanks again
AL
That fusible link goes to the battery terminal on the starter relay if that is what you are asking. It powers the entire car.
That is what I was asking LOL...Thanks. Just gotta put my gas tank back in and fire her up....fingers crossed.
Thanks to all for the advice.
AL
