Bee383
My 69 Bee won't kick down into a passing gear.mostly stock 383 holly 4 bbl.oem linkage all in good shape.have adjusted back and forth.the vertical rod bottoms out and still no downshift.motor and trans rebuild have about 1000 miles on them.runs good shifts up and down fine.could the lever at the transmission need to be adjusted?po never even tried to kick it down.so not sure if it worked after rebuild.thanks for any opinions.david
