Triplegreen500
- 10:03 AM
- Dec 3, 2020
- western Maryland
So, I have a "live" wood fireplace in my living room, marble hearth, stone chimney with terra cotta liner and fire bricks in the burn box, but it's only had a gas log in it to date (house built in 1987). I recently had a chimney inspector check it out so I could start burning wood (4 acres, plenty of deadfall - free heat!), and his answer was "well...it won't burn your house down, but you won't wake up in the morning". Apparently the chimney and the fire box were not fully finished masonry-wise, and they'd gas out anyone in the house if I had a real fire going in there.
So.
I'm looking into wood burning inserts, and my brain is starting to itch. Catalyst. Non-catalyst. Semi-catalyst. Jeez. The measurement part I can figure out; the BTU part I can figure out; I'm just trying to figure out all the other junk so I can sound like I have a clue when I talk to a local dealer (and so I know what they're talking about).
I'm figuring an insert, with a chimney liner (pipe) to the top of the chimney, will do it. I'll let them worry about the logistics, and if anything needs to be done to the masonry chimney beforehand. I can run an electrical circuit up from the basement easily enough, the panel isn't far away and that section of basement is unfinished.
Curious if anyone here uses an insert, if there are any brand preferences (I will only buy made in the USA) or brands to avoid, and if there are any "gotchas" or things to beware of... I briefly thought about a pellet insert, but that defeats the whole "free fuel" aspect of my acreage.
Appreciate any input, thanks!
So.
