- 7:49 PM
- Dec 4, 2009
- Pasadena, Texas
Title says it. What's the minimum vs maximum? Thanks!
That much eh??I'd stay with the .005 for the min side
They did spec a light thumb push at 70 deg F. If you have both parts really, really clean - and I mean clean - you can do a light push at almost nothing. I'm putting together a 390 for my truck and the pin almost gets stuck trying to slide it through the piston and rod but a delicate touch and she goes right in and floats nicely. The Ford book specs around .0007".
Rod side clearance will be on the order of .020".
Wrist pin 'to' rod clearance. Where I live writing 'wrist pin/rod clearance means how much does the rod fit need to be over the pin. Even tho .0015 would probably work, I would think it's on the loose side.
