How do I make this speaker fit?
dspur
12:31 AM
Albertville, AL
Purchased radio and speaker and the mounts under dash have two studs at each end. My speaker does not have those tabs I’ve seen on others.
Can I purchase those, fabricate something or should I just find a new center grill speaker. Rallye Dash 69 Super Bee.
TIA
Ok I see! Thank you! Now to look for a bracket.
There's a radio place in Blaine, Minnesota that makes a 2 speaker set up that fits right in there. It's actually for a radio conversion so that you can have a left/right, front/rear, but it would work if you don't find what you need.
Is this S&M electrotech?
That sounds like it. I am not out in the garage, but pretty sure that's them. I have have had them convert 2 radios. That front speaker set up has like two 2 1/2" speakers attached to a frame that goes right in where the old speaker was. The old speaker was 3x9 or something? Ask them about it. They will pre-wire the conversion, and you can cut to length. All wire ends, color coded wires, everything that you would need for installing your converted radio and instructions, if you were to go that route.
