- 1:32 PM
- Jan 14, 2009
- Shoreline, Washington
There have been some recent threads here where the subject of connecting loads at the battery on unmodified stock factory charging systems has come up. As an old-time Chrysler dealer/factory trained master tech, with that specific dealer experience back then and the many years spent designing and installing aftermarket 12-volt DC power/charging systems professionally for high-end automotive and marine applications, leaves me perplexed frankly about some of the responses from some otherwise seasoned appearing members here. Its clear some just can’t separate this stock factory charging system, in its original form, from every other 12-volt automotive charging system in general. The attempts at written descriptions and diagraming to differentiate this system appears to have fallen on some deaf ears, or blind eyes in this case.
For those that are interested in a fact-based video presentation on this subject, specific to the original Chrysler factory charging system design and touching a bit on ammeters/melted bulkhead connectors, I submit this video, forgive the amateur production quality. Feel free to critique the info presented but stay on subject of the as original Chrysler charging systems from this time period please.
For those who can’t separate this charging system from every other vehicle on the road, are convinced an ammeter-based charging system is a "ticking time bomb" while placing loads where ever, or already understand the negative impact of adding loads to the battery on the as original Chrysler ammeter-based charging system, don’t waste your time (about 28 minutes start to finish) watching this video, you'll never get the time back.
Disclaimer, once more, this information does not apply to any modified, ammeter by-passed, volt-meter converted, engine compartment main charge circuit by-passed Chrysler charging system, or every other charging system configuration on the planet not running a battery ammeter. Load placement does not matter for most other systems.
Adding in links to the slides used in the video.
Slide 1
Slide 2
Slide 3
Slide 4
Slide 5
Slide 6
Slide 1
Slide 2
Slide 3
Slide 4
Slide 5
Slide 6
