FabianC18
Hello everyone, hope you all are doing well.
I did a lot of research in this forum and others first but could not find the answer so I decided to start another turn signal thread
1973 Charger with Rallye cluster.
My turn signals don`t work at all. Nothing. Neither front, rear, left, right or indicator lights in the dash (Rallye cluster). Hazard lights and brake lights work fine (all 4 corners and dash). Light bulbs, ground at the lights and fuse are ok.
I have power at the turn signal switch TSS (red cable) when the TSS is in neutral. As soon as I move the TSS into either the left or right turn position, power is gone. When I measure (TSS in neutral) with a multimeter I get a fluctuating voltage of 8-10V (if I use a 12V test light instead of the multimeter its flashes dimly). Again, as soon as I move the TSS up or down (right turn, left turn), power is gone at the red cable (hazard lights and brake lights still working). I get exactly the same measurement at the TS flasher (two pin flasher next to the ash tray). Even at the power feed cable (black) cable to the flasher I get a fluctuating voltage. Same if I bypass the TS flasher. I thought the TS flasher makes the voltage fluctuating but it gets already fluctuating voltage. Lights, wipers, gauges, work fine. Dash lights and blower don`t work (haven`t started to look into those yet).
Does anyone have an idea why the voltage to the TS flasher is already fluctuating? I could not figure that out or is the TS flasher getting power from the hazard flasher? What else could make the voltage fluctuating? And why do I loose power completely when I activate the TSS? My TSS doesn't look great (right turn isn`t locking and horn pin is missing). Is the black horn cable needed to provide ground to the TSS ? If so, why are the brake lights and hazard lights working?
Any help would be very much appreciated.
Thanks a lot.
Fabian
Thanks a lot.
Fabian
