Wiring from trans to reverse lights
vsj100
5:40 PM
Hello B-BODY BROTHERS!
My car is a 68 Coronet auto trans. Please teach me how the wire gets from the transmission switch to the reverse light harness. My guess is that it connects behind the driver kick panel??
I can figure out the power and the center terminal - neutral safety.
As always THANKS!
do you have a factory service manual ? it show's it in the wiring section.
As always THANKS!
Is it a column shift or floor shift.
If it's a console shifter, this is the switch that's mounted inside the console to the shifter. I thought mine was dead, so bought a new switch, but then I realized the PO had not reinstalled the switch correctly. Cleaned my original up, and installed it correctly, and voila!, reverse lights.
