FOR SALE 1969 Plymouth GTX A36 Performance Axle Package with Hemi Suspension and Air Grabber - Updated
flamed34
10:26 PM
Raleigh NC
UPDATED Description and Pictures: After pulling it out for a showing and emptying out the trunk, it was realized that both rear quarter skins have been replaced with NEW and the trunk pan has been replaced with NEW. I had never pulled everything out and only believed the one skin had been replaced.
Please read the entire ad before asking questions. I don't need to sell, but decided it will be a while before I get to it as I have other projects that I would rather do first.
I have received the expected "you want what??!!!??" emails. My reasoning for the price is simple - very few unrestored cars are as solid as this. Sure, you can find one cheaper - but then spend $10,000 on sheet metal and labor. Go to AMD and add up what it costs to buy quarters and wheel houses, fenders, door shells, roof skins, inner and outer rockers, trunk pans, floor pans, frame rails, trunk lid and trunk gutters....and then factor in labor, yours or others. Add in the cost of buying a non-smoking, good running 440 or rebuilding a basket case. Add in a real N96 hood and upper plenum....
True RS23 GTX
Non-Original, but great running 1970 (F Code) 440 CI Engine. Maltese cross and X indicates .010" undersized crank. Upside down C indicates special crank from the best I can determine.
Engine running and walk around: https://www.youtube.com/watch?v=lvOASVjkMJU
From the fender tag (details found at http://www.andy440.com/tag2.htm)
594: Performance Axle Package - Hemi Suspension and Handling Package, 8 ¾ rear end with 3.55 Sure Grip, 11" rear & front drums (A36 Package)
093: 727 Trans
D32 Heavy Duty 727 3-speed
917: 440 cid 4 barrel V8 (High Performance) 375hp
E86: 440 cid 4 barrel V8 (High Performance) 375hp
R6: Scorch Red
X9: upper door paint black X9
1X Black vinyl top
6W (while stripe below molding in blackout area)
C16 console with woodgrain panel
V21 Performance Hood Treatment (stripes)
26 = 26" radiator
P6X: black bucket seats
ADDITIONALLY:
Non-original N96 Air Grabber Hood and upper plenum. DO NOT have air cleaner assembly.
SUPER SOLID. . ..repeat. . ..Super Solid
Rockers -- Solid
Trunk Floor -- New (a bit of scale from crappy paint on it)
Interior Floor -- Solid with the exception of the Driver's Side REAR floor. All there, but weak. (update, Passengers feels solid by there are pop rivets (on both sides) showing through the bottom so I assume someone has added a stiffening piece. You can see the pop rivets in one of the underneath photos but the pan looks good. I did not pull back the carpet)
Quarters -- New Skins
Inner Quarters -- Solid
Frame Rails -- Solid
Front Fenders -- Solid
Trunk Gutters - Solid
Doors -- Solid. Driver's side inner corner slightly rusted (see pics)
Gas Tank -- New
Exhaust -- New 3" exhaust
Seats -- Only rip is on passenger side outer top.
Needs typical rust repair around the back window due to the vinyl top. Lead is out of the seam. I would probably replace the rain gutters. A-pillars need a little work at top, but easily fixable.
Have all tail lights, headlights, bezels (now on the car). In the trunk along with trim, emblems, etc.
All glass is good EXCEPT the windshield is broken
MISSING: Rear Bumper (have brackets) and Front Bumpers (no brackets)
VIN on the radiator support and the trunk gutter all match
Drove it on the trailer. Unfortunately didn't realize the radiator brackets weren't on it, so a little rev pulled the radiator into the fan...that's the ringing sound if I manage to link the video....
This is absolutely the most solid GTX project I have seen.
Odometer is showing only 58,673 miles. While I can't verify, take a look at the lack of wear on the pedals.
No Title, but I have run the VIN through NC DMV and it came back clean. I haven't been able to find the time to go through the bonded title process, but it is easy (just did it on a vintage camper a few months ago -- requires a Form MVR-92H, an inspection, and a surety bond).
I have not found a build sheet in the car, but I have not pulled up the front seats or rear side panels.
Asking $15,500
This is just a bit of info to help you on the sale of the car. Looks like a solid project
the 917 on the tag
Is the build date, 9th month 17th day.
GLWS
the 917 on the tag
GLWS
I wrote a bunch so I'm sure it was easy to miss - I state under "Additionally" that it is has a non-original Air Grabber Hood and upper plenum.
I must have fat fingered the 917....thanks for pointing it out.
This is a Lynch Road car so the tag is read differently. The scheduled production date is May 23, 1969 (523). The 917 is the engine code: 440 4BBL, automatic transmission, heater, 375hp, Orange.
D
selling the Jeep wagon?
It will be once done...hopefully in a couple months. All the metal work is done, new interior bought, new glass bought, paint bought, brakes and weatherstrip on order. Now just need time to finish.
