Rikker
I checked past posts that come close to my problem, but still haven't found what I need? I put in a MSD ready to run. I removed the ballast resistor, the orange box and wired as the instructions show. The engine won't stay running after I let go of the key! After starting the engine if I hold the key slightly forward just before the starter kicks in it will stay running. I tested and I am not getting power to the coil with the ignition in the ON position, but I Do get power to the coil when the ignition is turned to start/run. I did a jumper from the battery to the positive side of the coil. I turned the ignition to start and it started and ran great.(Of course won't turn off until I remove the jumper from the battery)
Here are my questions?
1.) With the key in the ON position is there supposed to be power to the coil? (which is not currently happening)
2.) Could it be the ignition in the column? it worked fine before?
3. Is there a safe bypass or quick fix.
4.) What else could it be?
Thank you for any assistance in this area!
