Ace66
After building my first engine.1969 block machined .030 over 383 with a 440 source 440 crank and billet mains.It runs great but leaked oil minutes into 25 minutes brake in.Put 1800 miles on since then, didn’t heal it’s self.So tried it the fun way on my back.Second time instead of using Mancini’s billet kit I tried a stock bearing retainer and Fel Pro black seal.The machinist had line honed the mains to the block.He said he took off about .002 to .003”.A friend machined the factory bearing retainer (from another 383 block)square and removed .003”.I pulled trany,clutch and flywheel.So I could apply silicone to the back side.Ran it for twenty minutes no leaks.First sunny day took it out for 30 minutes.Leaking again.Inspected seals before installation lip toward front of engine Lubed seals. Looking for help.
