- 11:24 AM
- Jul 17, 2008
- South Jersey USA
Your one talented guy
No bracing?
Never had one down that far on the rear but did do one with a complete front end....frame rails and box. No bracing needed on that one.bracing is over rated........lol.......I'll have all the welding done before it goes on the rotisserie
eldubb440, great post!!! Did you replace any metal (besides the trunk pan which I assume you replaced)? Where did you get your metal? I see you took off the quarter panel skins, rear cross rail, floor extensions, trunk floor reinforcement set, trunk pan. What did I miss? (I probably need to purchase everything I mentioned since my stuff is rotten pretty bad and banged up.)
In what order did you reassemble the pieces? And novice question: is all the sheet metal welded on? (I'm pretty sure the answer is yes but I've never attempted what you've done 15 times ....)
Thanks! Terry
