cbodybob
- 11:23 PM
- Jan 10, 2014
- youngsville, NC
So my old Grand Caravan needs to be retired. I started a search in this crazy era of overpriced cars. I found this truck & went to check it out. Lot of miles but everything works on it. 4.7 V8 with power everything. 4X4 too. So this truck will replace the mini van in my vehicle line up once I get a tonneau cover on it. I paid cash. Now the mini van. 3.3 V6 runs great. I doubt I could get $500 for it so I think I’ll rebuild it. Get the air working again, gas gauge, it’s got a short that drains the battery, PCM is wonky, one door lock doesn’t work, hood & bumper damaged, clear coat peeling, paint fading, tires bad, needs alignment, struts, oil pan & trans pan leak, could use a new front engine mount, serpentine belt, polish or replace headlights, coolant leak, I think radiator, replace all the hoses, probably something else I’ve forgot. Spend about $2500-3500 & it would be good to go. Even though it has 185 thousand a newer used work van with say 40 K miles will run 20 thousand & up. Nobody would buy it after fixing all that stuff so just keep it for a back up & something to drive. Might even put a paint job on it. Single stage to get it looking nice too.
