70chall440
- 4:19 PM
- Feb 11, 2018
- Yelm, Washington
I am definitely not new to engine building however I thought it would be interesting to start this thread to see what opinions and comments it can generate (much like a group of people standing/sitting around a garage bench racing). Engine is a 1966 426 and was raced extensively. The block was windowed at some point but repaired and continued to be used as a race motor for some time.
So here are the specs that we are working with;
Bore = 4.305"
Stroke = 3.750
Heads = stock 1969 unmodified
CR = ~10.5:1
Exhaust = Headers of some kind, might make some fender well types
Intake = single 4BBL with EFI
Ignition = Unsure right now, probably either a Mopar Electronic unit or perhaps MSD
Trans - A833 4spd (23 spline because that is what I have)
Rearend = 8 3/4 or perhaps a Dana (I don't need to hear about the weakness of the 8 3/4, I am aware)
The engine will be going into a 70 Roadrunner that has been heavily modified with a tilt front end but otherwise is relatively stock appearing. Now, the intention of this car is to be a cool/neat street machine NOT a race car. I am NOT looking for max HP and this engine (as long as I have it) will not see 7K+ RPM. What I am after is reliability and decent manners but enough lift/duration to allow the engine to get out of its own way (it is a Hemi after all).
I have what I think is a Mopar solid lifter cam and as near as I can determine is PN 4349257 which is .524/.507 but I would rather run a hydraulic cam. I don't need/want something that is crazy lumpy with little to no vacuum. I am not sure if I am going to run power brakes or not due to the modifications to the front of the car, I might do a hydroboost system or just go manual discs.
So there you have it, let the fun begin and lets hear/read your thoughts, experiences and opinions on this subject.
Bore = 4.305"
Stroke = 3.750
CR = ~10.5:1
