1967 Belvedere II-What do OEM coat hooks look like
stat5
9:29 AM
MN
What do original coat hooks look like for a 1967 Belvedere II?
Do the GTX and Satellite use the same coat hooks as the Belvedere?
Thanks for any replys.
I have the one for my Satellite around here somewhere. I never reinstalled it because I didn't want to poke holes in the new headliner looking for the mount point. I'll look for it later if no one else comes up with a picture before I get to it.
Assuming I find it, I'll consider installing it if someone can post dimensions to the mounting hole.
I'll try to look at my unmolested 67's this weekend.
This is what mine looks like...
Assuming mine is "correct" - and I assume so as its a 47k mile car and reportedly has never been tampered with inside, i.e. all original interior - the screw hole is approximately 1 3/4 inch from the top of the moulding and 3 inches forward of where the trim moulding angles down.
Oh, and strangely, my car has only one, on the drivers side. never noticed before...
Yes that one looks correct. it is a 1967 only Item.
And drives side only is correct. If you hang something on the drives side the drive can still see just fine, but the pass side it will.d block the side view.
They are one year only.
