4 Speed to auto with bench seat
dcala84141
1:54 AM
New York
I have a 1968 RR 4 speed car. Been thinking of converting to automatic but I want to retain my bench seat and don’t want a column shifter. Anybody know if I can mount a floor shifter without bucket seats ?
I did that some years ago for a bracket-car build. Used a Cheetah shifter, mounted to an aluminum plate, which I attached using the 4-sped boot screw locations.
It was a no-cut operation, but I did have to drill a hole for the shifter cable.
I have a 1968 RR 4 speed car. Been thinking of converting to automatic.
Contact Winters Shifters.
I'ts a cable type. Installed
in my latest custom build.
Zero complaints. Works
great. Very robust, with
many options on mounting
and shift patterns.
I can help you set this up.
It can be mounted directly
to the floor or on a console
they supply. If you decide
to go this route, I will give
you the console. I didn't
need it.
Hello, was surfing thru threads and saw yours about converting from 4 speed to auto....wondered if you've accomplished that and if you had the 4 speed parts to get rid of?
Thanks!
One consideration is that with the shifter mounted directly in front of the bench it won't be able to be moved forward to let people in the back, etc. I ran this way for a while and if I wasn't going to go back to column shift I was going to build a tall bracket the mounted the shifter high enough that the front of the bench could still move forward. I've seen examples of this while searching the internet.
