Can anyone give me the length of the oil dip stick from the cap to the end for a 361 bb? I assume a383 would be the same? Thanks
Did you run the engine, if not run it and then check.I’d just like to know if my dip stick is correct. I just changed the oil and filter. Added about 4.7 qts. and the stick shows like a qt over full.
Length doesn't matter. Bottoming out sucks.it may never be long enough, depending on who you ask
Coffee can.like a tuna can?![]()
Thanks Kid, just what I needed.
