'73 440 HP Exhaust manifold part numbers
Charger Fan
7:29 AM
Jupiter FL
The right side manifold on my '73 Charger is P/N 3751071. Haven't taken the heat stove off the left side to get to the part number yet. However, the right side part number doesn't show up in the parts book. What should left and right side stock part numbers be for '73 440 HP?
3751071 is the cast number - it is correct for your car. The corresponding part number is 3751069. Cast number 3751068 is for a 73 440HP left. It’s part number is 3751067.
Casting numbers often differ from the actual part number by a few digits. In this case, the casting number (the number cast into the side of the part) is #3751071 and the actual part number is #3751072 (or maybe its #3751069) found in section 9-48-6 of the Parts Catalog.
That is the correct one for the right side. The left side should be cast # 3751068. Cast numbers are not necessarily the part #...
EDIT: I went to check a set mine have hanging and you got the correct responses of what I posted...
Part number 3751072 is the low power. Part number 3751069 is for HP.
