68 440 heat riser ?
SGTPaul
5:14 AM
Detroit Rock City!!
Hi, looking around and can't seem to locate a heat riser kit for my 68 440-exhaust manifold. Does anyone have a source for these? Thanks in advance.
Thanks but too clarify my request. Someone that has it available now. Mega said they have been on backorder for 2 years now when I talked to him recently. No idea when he will get more...
Did you try Mancini,Classic, Year One?
These are available at stupid prices. What is your reason for fixing this? The HP number was 2808446 and the non-HP number was 2585531. The only difference is the flapper size. So if your flapper is good the non-HP kit will work.
Good to know on the non-hp version. Even the shaft is the same huh? On the manifold set I'm going to use it was completely removed so I'm starting from scratch. I have others but would rather not try to remove them and then waste them.
