- 2:06 AM
- Jul 17, 2008
- South Jersey USA
Yes to AC. If your worried about power, turn it off to blow the doors off that Ford.
you can dust the ford with a/c on.... just sayin
Perfect.I added cruise to my 65 Coronet out of a imperial. It looked factory with the push button on the end of the turn signal arm.
Simpler alternative to cruise control. I bought the hand control unit I installed in my GTX for $500 on Ebay. The design has been around since the '60s, and bolted right in with no modifications to the car. Like the factory A/C, I typically don't use it on the way to a show, but both are nice to have on the return trip.Yes to AC. As I get older I appreciate the creature comforts the new cars have. Cruise on a 4 hour trip would be something else that I would enjoy.
Year One is having a sale on the whole AC system. I think it was around $2450 for my '69 Charger, which was a factory AC car when assembled. AC system was missing when I got it, but the firewall stubs for freon lines are there as are the dash controls. I mention this as the systems they offer are with or without factory air, so watch which one you pick.If you had an option to add air conditioning to a big block car, would you? How much hp would you lose? How is initial investment and maintenance cost (ac unit, pulleys, belts, hoses, charging annually)? And in the end, is it worth it?
I'm really tempted to play with one of these, it was even the original plan for my Coronet but since I need the heat part of HVAC too, I might as well get a full system. Maybe the next project car....I see the 'hidden' aspect coming alive. I know a smart fellow with a 1957 Chrysler long, low, smoke /silver colored 2 door coupe. It was a POS with a HEMI, anyway it's getting an electric AC for of all things from a Pr1u$. hidden under the package shelf! Just needed to upgrade to a Powermaster alternator.
It might not add value, but it can decrease the amount of time needed to sell.I've watched the auction results on restored factory A/C cars closely, and it doesn't seem to add anything.
I am looking for an aftermarket add on unit that would use a much smaller, much more efficient rotary A/C compressor. My '64 Sport Fury had factory air many year ago and that parts that I have are obsolete. the duct work is in the dash and if for not other reason, my wife would really appreciate a cool breeze, especially on a road trip.I put vintage air on my Big Block and I didn’t care what the part cost was(meaning it was worth every penny). In Houston A/C is just about a requirement. The tricky part for me was finding compressor mounting kits that work with no power steering, but with aftermarket heads.
Call Nostalgic Air Parts, they’ll have a bracket for you that should work. The setup uses a modern sander compressor. It was the only place I could find that had one for power steering OR non power steering setups. The eccentric didn’t line up with the pulleys I had so i sourced a shorter one from U.A.C. (Purchased through summit racing). If you decide to try it and have any questions let me know.I am looking for an aftermarket add on unit that would use a much smaller, much more efficient rotary A/C compressor. My '64 Sport Fury had factory air many year ago and that parts that I have are obsolete. the duct work is in the dash and if for not other reason, my wife would really appreciate a cool breeze, especially on a road trip.
