Remove or not remove
Duran75
7:26 AM
Phoenix AZ
I’m install this master brake cylinder. Because I need a smaller bore in order to work with the Willwood brakes. This master brake cylinder has a retaining clip. Do I remove the retaining clip or keep it?
Thank you for your help
Do you have power brakes or manual brakes?
The clip looks seated to me because the ends are the right distance apart.
What is the bore size? You do not want to remove the snap ring.
Just finished my install!! Everything worked out perfectly. Thank you all for your advice and help.
