zdillinger
Gents,
Is there such a thing as a 1-wire neutral safety switch on a 904 transmission? The trans that was just pulled out of my '73 has a 1 wire; the 904 that is replacing it has a three wire. I know that the center pole of the three wire can be hooked up to the Brown / Yellow wire that runs to the starter relay and that the other two poles are involved in the reverse light circuit (one brings power from the fuse box; the other runs to the rear harness). According to the shop, there is only the one wire in the harness, not three like there should be per the FSM.
Zach
Zach
