- 11:10 AM
- Sep 15, 2009
- State of insanity
From habit back in the garage way back when, I've been used to doing a 2-to-1 mix. 2 parts coolant & 1 part water.
Not totally correct.....the water pump shaft seal is a simple unbalanced (hydraulically) cartridge seal, in a carbon vs ceramic arrangement. The coolant, albeit a combination of water and ethylene glycol in you're favorite ratio, provides the seal's face lubrication, between the stationary and rotating members. Temporarily operating the pump without sufficient coolant present can damage the seal....it must have coolant in order to survive.......just something to consider......The cooling system is designed to flow water and antifreeze
If 100% antifreeze makes it to the seal on water pump it can damage it so always mix some water when adding to an empty system
If you do a compete flush and clean you can change to any antifreeze you wish to use
My experience is that shrouds are very important. Original fans seem to work the best. Haven't had much luck with electric fans in severe overheating problems. I tried water wetter. It might help if you have a minor problem but I saw no positive results from it or any other of the snake oil magic fixes for severe problems. Seems like a good factory radiator and fan and all the shrouds that came with the car are the best answers. I know we are talking Mopar's here but I also dabble in old Ford flatheads and correct timing is critical with themIs one more efficient at cooling than the other.
Also, thoughts on "Water Wetter" as additive?
Thanks for any input
100% antifreeze is worse than dry as it will tear not just wear the seal surfaceNot totally correct.....the water pump shaft seal is a simple unbalanced (hydraulically) cartridge seal, in a carbon vs ceramic arrangement. The coolant, albeit a combination of water and ethylene glycol in you're favorite ratio, provides the seal's face lubrication, between the stationary and rotating members. Temporarily operating the pump without sufficient coolant present can damage the seal....it must have coolant in order to survive.......just something to consider......
BOB RENTON
I guess we'll just have to agree to disagree........100% antifreeze is worse than dry as it will tear not just wear the seal surface
