ga66mopar
I have been thinking about the advantage of the larger rotors. I have used both sizes and I didn't see any real huge difference. Both use the same size calipers and brake pads so the contact area is the same. The larger rotor would rotate at a slightly slower rate at the same tire speed than the smaller rotor. That could make the larger rotor run a little cooler under extreme use but I wonder how much they really improve on stopping distance.
Most high performance brake kits have a larger caliper for more clamping power and a larger brake pad for more contact area but using factory mopar brake components these are the same.
I have to admit I like using the larger rotor because they make me feel like I have better brakes but I'm not sure there is much of a difference under normal use.
