15" Magnum 500s
I bought some new Magnum 500s for my 73 Runner and the fronts will not fit the hub of the rotor...did rotors have different size hubs?
The wheel guy said they fit stock rotors
AL
I bought 4 Scott Drake aluminum mag 500's ( 15 X 7's ) which are a Legendary Wheel Company rim and they fit my 68 Dart GTS with a disk brake conversion kit with no problems. I like these rims much better than the wheel vintiques mag 500 rim. The aluminum rims are a lot lighter compaired to the wheel vintiques. I had wheel vintiques on a 68 coronet rt and the chrome plating is extremely cheap and scratches very easy even using micro fiber rags. The Scott Drake rim is a highly polished machine finish then clear coated.
The hub the OP has looks like it has a cast center.
I'm running ford Magnums on my 73 and they fit fine.
As stated "original" magnums have a stamped center and fit both ford and Mopar hubs.
I'd see how much a machine shop would charge to machine the center for your hubs.
Had both rims done at a tire/machine shop, they took tires off bored them reinstalled tires and balanced for $120. Like I said they fit 5 other classic Mopars just fine..and yes the stamped ford rims also fit fine just could find any nice ones.
AL
The ones I bought look great!! LOL.. thanks again AL !
Doing great. Car headed back to paint Tuesday for touch ups and cut/buff. Then I can finally put my door glass and interior back in and go Vroom Vroom !
