15x7 magnums and 245 60 15 on all four corners?
hillbillyGTX
10:24 AM
Alabama
HI All,
Anybody running this tire and rim setup, 245 60 15 square on 15x7 on a 67 GTX? Pics, any fitment issues?
Thanks,
Casey
1967 Plymouth GTX, 440, Dana 60, Auto
My 67 GTX with 14 inch rims now.
Yes they fit perfect on there!
Since you have an auto the Dana must have been added at some time. You might want to check its year as I believe the 68/69/70 Dana’s are a little wider than 66/67 models. I have a later 8-3/4 under my 67 and with 7” magnums it’s a bit of a struggle to get the rears on and off with 215/75-15 tires. Any wider tire and I would have to unbolt the shackles.
245/70/15 on 15x7” Magnums with 3.75” backspace. Never a problem.
Mine does have a Dana. And it is from a 1966.
That said
Getting the tire out from under the car requires I lift it from the one side.
Or
If I pick it straight up from the center diff with both wheels off the ground.
I can not get a tire out unless I set the chassis on jackstands and let the rear axle drop down
Hey, it is a 66/67 dana according to the date code. Thanks for the info!
Just an fyi,
In my post above. the 2 pics on the top are recent versus the 2 lower and the car has had suspension work to lower the rear of the car slightly. If that matters
While you are probably correct, adding a Dana to an auto car was a factory option.
I am sure the dana was added to my car, but, I have owned it since 1987, so it feels like a factory option to me! LOL
That size looks perfect on almost any car. Except I always like a little more tire under the rear.
Dana and automatic, not and option until 1969.
I stand corrected. Never owned a 67, but mistakenly assumed a guy could have always ordered a Dana in any 440 car.
Messagge for hillybillyGTX: Want to make sure I understand that you are running 15 x 7 w/245-60 on all 4 wheels? What brand wheel are those (they are sweet) and what is the offset? Looking for new wheel/tire set up for my 67 Convertible. I keep hearing 245 's won't fit (too wide) but are they?
Thanks for this info.
