FOR SALE 1962 413 Street Wedge short block for sale in Beaumont, CA
Ghandi18
2:42 AM
Beaumont, CA
The motor has been sold. Thank you.
***Update*** It does not appear that this is a street wedge block based on some information provided by another forum member. Because of the cupped pistons, it seems like this is more likely a low compression motor out of a pickup or a motorhome. I would still like to find a good home for it, as I have no need for it. It looks like you can still turn this into a 400HP to 500HP motor with the right components. Asking $200. Thank you.
Hello,
I inherited a short block from a buddy of mine and I would like to find a good home for it. My buddy believed it to be a Max wedge but, based on the color and numbers, I think it is only a street wedge. He was going to install it in his 1968 Charger, but the owner of the property who was storing his Charger sold it with the heads, intake, and headers inside. I do not know what vehicle this motor came out of. So this block only comes with the crank shaft, cam shaft, and pistons.
I see no visible signs of repairs or damages.
If you would like more photos I can provide them at your request. I apologize in advance if I do not have all the information you need, but I will do my best to get it for you.
I am located in Beaumont; CA. Local pickup is best as shipping will be expensive.
Any reasonable offer will be considered.
I will only be able to check this thread every couple of days or so. So please bear with me if I don't get back to you right away.
Thank you.
With the dished in pistons, this appears to be a low compression engine . Very likely from a truck or motor home........................................MO
Thank you for the info. Does that make a difference as to the value or whether or it is usable for application in this forum?
With that cast date would it be a 1963 application?
To be honest, I am not sure. I am not a motor guy so I don't want to give bad information. I just based the date off of the stamped year.
I will try to locate it and will post more photos if I do. Thank you.
